engine won't start
Old Jul 28, 2004 | 10:17 PM
weraider30's Avatar
Default engine won't start
just dropped a d16z6 into my hatch...got everything put on...tried to start it and it won't even crank over at all...not the battery, brand new battery, not to mention headlights and everything else works...didn't think it was the starter, because it wasn't making any noise at all. but if anybody has had a similar problem or has any insight on the situation please feel free to post. thanks.
Old Jul 29, 2004 | 07:00 AM
weraider30's Avatar
Default Re: engine won't start (weraider30)
bump....i need to get this thing goin
Old Jul 29, 2004 | 09:06 AM
bruthaboost's Avatar
First, are you getting voltage/current on the starter and/or solenoid. Put a multimeter on the terminal and look for battery voltage.
Old Jul 29, 2004 | 07:56 PM
weraider30's Avatar
Default Re: engine won't start (bruthaboost)
made some adjustments tonight, got the fuel pump to turn on, but engine still won't turn over, didn't have a multimeter on hand, but does anyone else have suggestions?
Old Jul 30, 2004 | 09:29 AM
weraider30's Avatar
bump
Old Jul 30, 2004 | 09:41 AM
You don't need the multimeter to tell if the starter/solenoid works. You need it to tell you if there is voltage getting there (you can use a test light as well-very cheap but effective) That will tell you where to go next. Most likely there is no voltage getting to the starter solenoid. Find the circuit that opens the voltage for that solenoid. I don't have the helms in front of me, but that is your next step. You can hope for that magic bullet diagnosis, but from reading most the posts on this forum, that's not going to happen.
Good luck.
Old Jul 31, 2004 | 09:52 AM
weraider30's Avatar
The starter is fine, it was swapped with a perfect condition one from an engine that was just pulled.
I believe that there may be wires loose around the ignition switch.. I will check it out and post what I find.
Old Jul 31, 2004 | 12:09 PM
A1's Avatar
A1
what about the body ground?
honda connection
5511 mission st.sf,ca.
415/5871079
Old Jul 31, 2004 | 01:17 PM
weraider30's Avatar
Default Re: engine won't start (d16why8)
all grounds are good, just took the dash off thinking the retards that owned it before had a kill switch of some sort
Old Aug 1, 2004 | 06:01 AM
weraider30's Avatar
finally got it going...the retard who owned it before had something rigged to the clutch sensor and had cut one of the clutch wires, so after taking the dash out and a couple of hours we got it going
willpower102
Nov 8, 2011 07:50 PM
KnuckleZ
Jun 25, 2007 02:33 PM
xteg95
May 26, 2003 05:15 PM
Superhatch
Dec 24, 2002 02:36 AM
vtecdc2
Dec 1, 2002 11:35 PM
