CRVTEC fuel and hondata question.....
im almost complete with my b20vtec build which is made up off...b20b block, around 10:5:1 cr, gsr head, skunk2 mani, jdm itr header, skunk gears, and CTR cams.....i previously owned a builts gsr w/ CTR pistons and the same head which ran off of a kenji chipped p28...from what ive heard i will need a greater amount of fuel and i was thinking about upgrading from the chipped ecu to 310 injectors as well as hondata s100....i was wondering if anyone had any advice/suggestions in order to supply my setup with adequate fuel in order to be tuned.
Thanx BRYAN
Thanx BRYAN
yeah the adj fpr is a must if you dont already have it, the hondata is highly suggested by me or at least something that gives you a bunch of tunability, find a good tuner and you should be good to go, im not so sure that youll necessarily need an upgraded fuel pump, but it couldnt hurt
fuel pump wont hurt.... I have run my crvtec for a while in my crx, w/ the stock pump, stock b16 injectors and on obd-0 b16 ecu shipped, fuel pressure incressed, and ran fine....the w/ the "z" pistons and a b16 head, stock everthing from intake mani, to even the header.. 168 hp 13.8 1/4 (crx untuned).........get the fuel pump cheap inssurance....
wat should i have my FP set to in order to get the car to the dyno after its fully put together? I dont want to run to lean or run to rich and wash the cylinder walls after i just spent all this money putting it together...thanx again guys BRYAN
SIReg9
Apr 30, 2003 08:02 AM
