Minor Track Woe! Please Help
Car: 93 Civic CX
Motor: B18a1
Problem:
^The piece circled above, slipped out of the bushing and caused the linkage to rest on the exhaust. This was my third run when it happend.
What could of caused it? The motor has been in for about 4 weeks now.
Motor: B18a1
Problem:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">same **** has happened too me,
most of the time its a combination of loose bolts and a motor that moves around to much. its not a big deal</TD></TR></TABLE>
thannnnnnk you yeah engine movement
oh yeah I'm not sure isn't there a nut on the other side holding that bushing in place. It's been a while since I looked a shifter assembly.
edit: nm but I just seen shifter assembly pic from CRX and the end of the shaft right after the bushing, it's spread apart, here I will get a picture in a second
Take a look at that
http://www.overboost.com/getim...hot=0
Take a look at that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlepT ej6 »</TD></TR><TR><TD CLASS="quote">bump for my bro, would an engine damper help, like the j's racing or those others on the market?</TD></TR></TABLE>
no, motor mount inserts(37shipped)/new solid mounts would wok (300+), but not a engine damper. That damper is designed like ****, because it on only one side of the engine (instead of center or both sides) It can cause baise movement and will have the engine flex because the one side will basicly not move, the other will be realtively free. Not the best idea. Don't belive the JDM hype.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">oh yeah I'm not sure isn't there a nut on the other side holding that bushing in place. It's been a while since I looked a shifter assembly.
Take a look at that
http://www.overboost.com/getim...hot=0</TD></TR></TABLE>
Links didnt work but i see what your saying. I just saw my SOHC linkage and the end is flared out. guess thats what imma do.
Take a look at that
macrohard
Dec 13, 2007 01:57 AM
boomersz
Apr 1, 2007 08:52 PM
