B11 pin on 1994 GSR what is it? ******CYP -P*********
Old Jul 28, 2004 | 09:10 PM
the.hamburglar's Avatar
Default B11 pin on 1994 GSR what is it? ******CYP -P*********
i found out what it says on this one page. B11-ORNANGE-CYP. what is CYP???
anyone??
Old Jul 29, 2004 | 05:46 AM
JimBlake's Avatar
Default Re: B11 pin on 1994 GSR what is it? ******CYP -P********* (hamburgler)
Cylinder-position sensor?
You got 3 little star-wheel sensor things down in the distributor. CYP, TDC, & CKP. The ECU uses these together to decide when to fire the injectors & spark plugs.
Old Jul 29, 2004 | 04:33 PM
Default Re: B11 pin on 1994 GSR what is it? ******CYP -P********* (JimBlake)
thanks alot, so does this mean that my ecu is fried? how can i fix this?
Old Jul 29, 2004 | 04:44 PM
wait, i just thought of something. can i cut the wire 2" at the ecu and 2" at the dizzy and then run some old one i have in my garage from the ecu to the dizzy outside the door just to see if it will start?
Old Jul 29, 2004 | 06:27 PM
JimBlake's Avatar
Yeah, that would be OK. Probably you only have to splice in enough wire to fix the burned part. I got no way to know whether your ECU is fried, but the simple fact you can pull codes from it is a good sign.
Old Jul 29, 2004 | 07:44 PM
nonono, i cant pull codes from it. actually ill try and trigger a code by unplugging the 02 senser under the car that threw a code a couple months ago. thanks man
rizzuto
14
May 17, 2013 07:59 PM
txtuner
Feb 22, 2011 05:43 PM
civic_jdm
Jun 6, 2005 10:18 AM
hondacrx90
10
Apr 9, 2004 05:45 AM
kim_2_da_chee
May 30, 2003 06:18 PM
