gaping rings?
Old Jul 28, 2004 | 08:10 PM
Sport_Injected's Avatar
Default gaping rings?
what exactly does this mean?
and also, say you have your boreing your block to fit oversized CTR pistons (.25) then they hone your cylinders after they are done (which they usually do) doesnt the honing mess up how well the pistons seal, because it makes the cylinders slightly bigger? i think what im trying to ask is if they bore turns out to be slightly too big is there a way to fix it?
Old Jul 28, 2004 | 08:20 PM
Ti3d in's Avatar
Default Re: gaping rings? (Sport_Injected)
Gapping the rings means to adjust the gap between the ends of each piston ring by filing them down. The size of the gap depends on your setup. If you're going to use oversized pistons, give the machine shop your pistons, and tell them the clearances you want to run. They'll bore it, and then hone til you get that clearance.
Old Jul 28, 2004 | 08:30 PM
Default Re: gaping rings? (Ti3d in)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">Gapping the rings means to adjust the gap between the ends of each piston ring by filing them down. </TD></TR></TABLE>
the gab between what and what? the gap between the ring and the cylinder wall?
Old Jul 28, 2004 | 09:16 PM
Ti3d in's Avatar
The pistons rings aren't a complete circle. There's a gap in it.
Old Jul 29, 2004 | 03:15 AM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sport_Injected &raquo;</TD></TR><TR><TD CLASS="quote">
the gab between what and what? the gap between the ring and the cylinder wall?</TD></TR></TABLE>
read the quote u just quoted......
DC4 Rasta
Jan 5, 2007 06:44 PM
HondaGuy02
May 22, 2005 01:47 PM
Trailz-EX
Dec 1, 2004 07:50 PM
B19CivicHB
Jun 19, 2003 04:15 PM
