idle=wtf?
Old Nov 27, 2001 | 12:00 PM
3.3.3's Avatar
Default idle=wtf?
Modified by 3 3 3 at 4:39 PM 8/31/2004
Old Nov 27, 2001 | 12:02 PM
junglistgsr's Avatar
Default Re: idle=wtf? (maks)
low coolant maybe? air in the coolant? reset the ecu and see if that changes it...and check coolant level.
Old Nov 27, 2001 | 12:16 PM
3.3.3's Avatar
Default Re: idle=wtf? (junglistgsr)
thanks bro.
Old Nov 27, 2001 | 03:30 PM
Jackson's Avatar
fast idle thermo valve. has to be. its under your throttle body. take off the three 10mm bolts that hold it to the bottom and undo the water hoses going into it. then take off the plate and turn the white plug with a wide flat head screwdriver. there will be a spring under it pushing it up, so you have to put pressure on it to tighten it. it might not make sense now, but once you get started it will come together. IM me if you have any other questions.
Old Nov 27, 2001 | 03:37 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: idle=wtf? (Jackson)
satisfaction jaxion is coorectamundo
Old Nov 27, 2001 | 03:50 PM
3.3.3's Avatar
thanks a lot. i think that might do it. the coolant level was cool, and we reset the ecu. will try. thanks a lot.
max
Old Nov 27, 2001 | 04:10 PM
i said coolant because when i had a coolant leak in my accord it tripped the ECU and make the revs constantly go up and down between 1k and 3k.....
Old Nov 27, 2001 | 07:27 PM
NOSed_b18b's Avatar
Ya, my car did basically the same thing this past week. But it was my tb gasket and I was low on some coolant. Simple fix. Anyways, post back if any good/bad results.
Old Nov 27, 2001 | 11:08 PM
Mista Bone's Avatar
D Tranny Guru
FWIW.....
Dunno about B motors, but on SOHC's you can get the plate off with removing the FITV from the TB or even the car. I then used a stubby slotted screwdriver to tighten the plunger.
Old Dec 7, 2001 | 11:10 AM
CTR94Joes's Avatar
Default Re: idle=wtf? (ChrisOnePointSix)
No sorry But Mr. Jackson is right about this one. The same thing happened to me this past summer and I came to the boards looking for help but no one at the time had the answer for me. Reading a few books helped me out. But no I have the same problem and I have to replace the Fast Idle Thermo Valve on my Civic/GSR
P. Hunter
Apr 7, 2013 05:46 AM
EKHWhat
Feb 19, 2007 05:24 PM
T3T495GSR
Jan 3, 2006 08:57 PM
99ctr
Oct 5, 2005 12:23 PM
topher
Mar 22, 2002 12:56 PM
