fuel pump (short somewhere?)
Old Jul 28, 2004 | 02:31 PM
HatchBox's Avatar
Skoobie no more...
Default fuel pump (short somewhere?)
i just need to know where the 4 wires going into the sender unit on the tank run to under the dash, i think one goes to main relay, 1 is to ground
these 4
Modified by HatchBox at 7:56 PM 7/31/2004
Modified by HatchBox at 8:25 PM 7/31/2004
Old Jul 28, 2004 | 03:38 PM
HatchBox's Avatar
Skoobie no more...
Default Re: fuel pump (HatchBox)
Old Jul 28, 2004 | 03:41 PM
sit220's Avatar
so u got power at all?at the fuel pump
and how u know ur main relay it fine
Old Jul 28, 2004 | 03:45 PM
HatchBox's Avatar
Skoobie no more...
Default Re: fuel pump (sit220)
no power to the fuel pump sender unit.
everything else has power..
when i turn the car on the relay clicks.
Old Jul 28, 2004 | 04:02 PM
sit220's Avatar
my main relay is bad and still clicks
go to ur fuel filter and take the 17 bolt out and put ur car in ignition if u see fuel caming out the line then u have fuel
Old Jul 28, 2004 | 04:04 PM
sit220's Avatar
check all ur fuses
Old Jul 28, 2004 | 04:16 PM
HatchBox's Avatar
Skoobie no more...
fuses are all fine.
pump doenst turn on, wont pressureize
Old Jul 29, 2004 | 02:23 PM
HatchBox's Avatar
Skoobie no more...
alright instead of searching for the short, im just going to run 3 new wires. . . can anyone tell me where the 4 wires on the sender unit go?
i beleive 2 go to the main relay but where does the 3rd go? and the black is obviously a ground.
Old Jul 29, 2004 | 03:00 PM
HatchBox's Avatar
Skoobie no more...
weee
Old Jul 29, 2004 | 04:39 PM
HatchBox's Avatar
Skoobie no more...
someone <U>has</U> to know
Old Jul 29, 2004 | 05:27 PM
crxtim's Avatar
will the pump turn on if you supply 12v to it? accually there is only one wire from the pump to the main relay that supplies 12v+ to the pump, the other is only a ground. there is a harness that runs from the plug inside the car to the top of the tank, you could have maybe pinched a wire around there maybe. it sounds like a bad main relay. i would do what sit220 said and make sure fuel i coming out. you can im if you have any questions
tim
Old Jul 30, 2004 | 12:04 PM
HatchBox's Avatar
Skoobie no more...
Default Re: fuel pump (crxtim)
just need to know where those 4 wires on the sender unit go....
Old Jul 30, 2004 | 12:30 PM
HatchBox's Avatar
Skoobie no more...
nobody has a wiring diagram
Old Jul 30, 2004 | 12:43 PM
bossman032's Avatar
Hey bro here is how u test it.
Yellow and black and black. Are the two main wires you have to worry about. Fuel Pump sender wire has its own sensor.
See when u turn on ur ignition see if you get voltage at the Yellow and black power wire and black is ground.
Or you can get a relay and run power direct from the Battery and if you would like more info on this let me know.
Most likely your ground on the fuel pump is not working or your two low on fuel. Did you make sure your fuel pump is sitting right in the tank the warblo isn't exactly like the stock fuel pump.
FYI: if you put fuel in your car and sender doesn't go up means either your pump is not sitting right or sensor is fucked up.
Old Jul 31, 2004 | 03:57 PM
HatchBox's Avatar
Skoobie no more...
Default Re: fuel pump (bossman032)
modified, anyone with a complete wiring diagram please help a h-ter out
Old Jul 31, 2004 | 10:58 PM
HatchBox's Avatar
Skoobie no more...
someone .,...anyone...
Old Aug 1, 2004 | 08:43 AM
HatchBox's Avatar
Skoobie no more...
SpoonEk253
41
Oct 3, 2022 03:21 PM
dgdarien
Jul 19, 2017 05:48 PM
ghettoda9
Apr 13, 2011 10:03 AM
self_made
Dec 30, 2004 03:05 PM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
