Fuel pump not getting power?
Old Dec 21, 2004 | 11:13 PM
self_made's Avatar
Default Fuel pump not getting power?
On my friends freshly rebuilt b16, when he went to start it up, it wasnt getting any fuel. Upon closer inspection of fuses, main relay and stuff, it turns out the fuel pump was not getting power. The same thing happened to my gf's civic when it was put back to stock, the fuel pump was not getting power. any idea at what could be causing this?
Old Dec 22, 2004 | 01:53 AM
TurboEH2's Avatar
Default Re: Fuel pump not getting power? (VTECNLUDE)
if it wasnt a fuse or a main relay, i would try running a constant 12v to it and see if it cuts on, if it doesnt check grounds or see if the pump is bad. if it does cut on get ready to trace wires. if all the wires check out, look over the fuses and main relay again
Old Dec 22, 2004 | 02:47 AM
FORCED FED TEG's Avatar
New User
Check your ignition coil. When my went bad the fuel pump wound not work.
Old Dec 22, 2004 | 07:57 AM
self_made's Avatar
Default Re: Fuel pump not getting power? (FORCED FED TEG)
well, we ran a direct line of 12v power, and it turned on. at the plug of the fuel pump, there was ground, but no power. we swapped over 3 main relays, so that wasnt the problem. do any wires from the engine harness control the fuel pump?
Old Dec 22, 2004 | 12:03 PM
8200RPM's Avatar
local hippie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FORCED FED TEG &raquo;</TD></TR><TR><TD CLASS="quote">Check your ignition coil. When my went bad the fuel pump wound not work. </TD></TR></TABLE>
&lt;girlfriend mentioned above/owner of one of the civics.
thats odd... my coil went bad some while ago and i dont recall it affecting the fuel pump... hrmm
then again i never correlated one to another.
Old Dec 22, 2004 | 12:28 PM
TurboEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECNLUDE &raquo;</TD></TR><TR><TD CLASS="quote">well, we ran a direct line of 12v power, and it turned on. at the plug of the fuel pump, there was ground, but no power. we swapped over 3 main relays, so that wasnt the problem. do any wires from the engine harness control the fuel pump?</TD></TR></TABLE>
ive been searching my comp for 2 hours for the damn fuel system wiring schmatic, but i think i deleted it when i reformatted this POS. imma try and get another copy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8200RPM &raquo;</TD></TR><TR><TD CLASS="quote">
then again i never correlated one to another. </TD></TR></TABLE>
ive never seen this either, but then again ive always seen fuel pump problems as what i listed.
Old Dec 22, 2004 | 12:31 PM
VTC_CiViC's Avatar
Default Re: Fuel pump not getting power? (LSturboEH2)
Just out of sheer curiosity, you checked the actual FUEL PUMP fuse yes?
It amazes me how many EK owners don't realize they have one.
BTW, convert to a direct line, gives the pump consistent power and keeps the bypass working full time.
Old Dec 22, 2004 | 12:35 PM
TurboEH2's Avatar
Default Re: Fuel pump not getting power? (VTC_resurected_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_resurected_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Just out of sheer curiosity, you checked the actual FUEL PUMP fuse yes?
BTW, convert to a direct line, gives the pump consistent power and keeps the bypass working full time.</TD></TR></TABLE>
yeah that 12v system i mention will work, just dont forget to cut it off
Old Dec 28, 2004 | 12:20 PM
self_made's Avatar
any one else?
Old Dec 28, 2004 | 12:34 PM
Muckman's Avatar
Moderator in Chief
I know if the ECU isnt getting power or not hooked up on Integras, the fuel pump will not prime.
Old Dec 28, 2004 | 02:00 PM
self_made's Avatar
Default Re: Fuel pump not getting power? (Muckman)
the ecu is hooked up, if we put 12v power to the fuel pump, the car will turn on. but the CEL doesnt work, the fuel pump doesnt turn on(if we dont put power to it) and the radiator fan doesnt turn on either.
Old Dec 28, 2004 | 02:46 PM
VTC_CiViC's Avatar
Relay
Old Dec 28, 2004 | 02:52 PM
Too_Smooth's Avatar
Make sure that all the connections to the wire harness are completely snapped together...I'm talking about the three main ones on the drivers side firewall.
I had the exact same problem you had before.
Old Dec 28, 2004 | 02:58 PM
self_made's Avatar
3 relays have been swapped around, none of them fixed the problem
Old Dec 28, 2004 | 03:13 PM
self_made's Avatar
also, the speedo doesnt work.
Old Dec 30, 2004 | 08:46 AM
self_made's Avatar
anyone?
Old Dec 30, 2004 | 02:16 PM
PrettyLude's Avatar
check the grounds carefully, try the ground on the tranny to the chassis, the ground on the thermostat housing, and all other grounds
Old Dec 30, 2004 | 03:05 PM
self_made's Avatar
Default Re: (PrettyLude)
we've check the grounds liek 17 times, taken the harness out and put it back in a couple times, and nothing...so i doubt its the grounds.
SpoonEk253
41
Oct 3, 2022 03:21 PM
turbogsrbaby
Apr 6, 2013 12:04 PM
jun10r27
Honda Civic (2001 - 2005)
Dec 15, 2009 08:35 PM
zippakilla
Feb 6, 2009 04:01 AM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
