obd2>obd1 conversion ? (already searched)
Here is the situation... I have a 96 DX (D16Y7) auto.... I also have a JDMShit obd2>obd1 harness and a p28 which I believe is auto... anywho I plugged everything up and the car starts fine... the only problem is that it was idleing a little rough.... It seems that every cycle it kinda "hiccups"... I also have to mention that my O2 sensor are not on... With my stock ECU it idles fine no hiccups... Anyone have any idea why its "hiccuping"? Do I have to do anything to my dizzy? Is my timing off because of my dizzy?
Did you change the pins to the ecu they must be change its two 12 and 14 i dont know on what plug though. that could be it. or if you have already did that maybe a vacum hose in the wrong placeor leak. I think on connector 32p you switch iacv 12 to 14 and 14 two 12. but im not to sure.I forgot what it was i did!
good luck!
Modified by civicHBphtride at 5:13 PM 7/28/2004
good luck!
cant i just repin the iacv? anyone have instruction on this? or have another solution?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicHBphtride »</TD></TR><TR><TD CLASS="quote">Did you change the pins to the ecu they must be change its two 12 and 14 i dont know on what plug though. that could be it. or if you have already did that maybe a vacum hose in the wrong placeor leak. I think on connector 32p you switch iacv 12 to 14 and 14 two 12. but im not to sure.I forgot what it was i did!
good luck!
Modified by civicHBphtride at 5:13 PM 7/28/2004</TD></TR></TABLE>
Thanks for the feedback!
good luck!
