QUICK QUESTION----->Prelude idle control valve!!!!!
I was just wondering if there is any difference between the 1992-2001 Prelude idle control valves. Also, is there any difference between JDM and USDM ones?
Thanks for the help
Thanks for the help
OK...
I found out that the 1992-2001 Prelude idle control valves are all the same. Now I just need to know if there is any difference between the JDM and USDM ones. Thanks again
I have compared a US and JDM IAC side by side and although the size and shape varied only slightly, it had all the same connections and works exactly the same...
Thanks guys...
I REALLY appreciate it
EDIT----->Does anybody have one of these for sale? PM me PLEASE
Modified by H23AHybridEG at 9:45 PM 7/28/2004
!EDIT----->Does anybody have one of these for sale? PM me PLEASE
!Modified by H23AHybridEG at 9:45 PM 7/28/2004
Too be honest I think I might... I will go have to check the many boxes of prelude spare parts that I have laying around the garage and I will PM you to let you know... If I still have it, which I think I do, I know it is a JDM one just to let you know, but it is no different...
Is it acyually broken somewhere, or does it just not seem to be working properly? I just had mine off due to an erratic idle, and cleaned it all with brake cleaner. Put it back on, and it seems to be working fine.
Just a thought that you may be able to clean it before replacing it with a new one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonlude »</TD></TR><TR><TD CLASS="quote">Is it acyually broken somewhere, or does it just not seem to be working properly? I just had mine off due to an erratic idle, and cleaned it all with brake cleaner. Put it back on, and it seems to be working fine.
Just a thought that you may be able to clean it before replacing it with a new one?</TD></TR></TABLE>
I actually don't even have it. We replaced the upper plenum of my intake manifold (JDM H23A) with the upper plenum from a JDM H22A because the H22A IACV is on the front of the plenum...not the rear.
Yeah, the upper plenum is different. Not only is the IACV on the backside instead of the front, but it is a 3 wire (like the Euro R) instead of a 2 wire.
turbodailydan
Feb 24, 2010 08:59 AM
dnbruut
Jan 12, 2007 02:38 AM
