RADIATOR SUPPORT REPLACEMENT
Old Jul 28, 2004 | 10:54 AM
wisehondachick's Avatar
Default RADIATOR SUPPORT REPLACEMENT
I am in the process of replacing the front end on my 99 Civic (not by choice), the radiator support unit is giving me trouble. It is obviously welded on and right now I am in the process of drilling out the welds to get it off. I have a replacement for it, is this part supposed to be welded on as well? I don't know if I can just bolt it on or if it needs to be welded back on for the car to be right again. Also, do you know if I am going to have to remove the condenser to get this done? Any help would be greatly appreciated. THANK YOU!
Old Jul 28, 2004 | 10:59 AM
spoonishEJ1's Avatar
Default Re: RADIATOR SUPPORT REPLACEMENT (wisehondachick)
im pretty sure it just supposed to be bolted on
Old Jul 28, 2004 | 11:21 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: RADIATOR SUPPORT REPLACEMENT (spoonishEJ1)
No, I do believe it has to be welded back on. You could probably call a welding shop and have them send someone over with a portable welder to do it for you, unless you have access to a welder.
Old Aug 11, 2004 | 02:39 PM
YumVTEC's Avatar
Default Re: RADIATOR SUPPORT REPLACEMENT (TouringAccord)
all 92+ civic radiator supports are weld-on.
Old Aug 11, 2004 | 02:55 PM
_Spugen_'s Avatar
Just use a air chizzle.....just pops right off....
Old Aug 11, 2004 | 03:31 PM
JDMisGOOD's Avatar
Default Re: (SpugenEG)
Yes it has to be welded on!
Old Aug 14, 2004 | 10:59 PM
DubyaAye's Avatar
Default Re: (JDMisGOOD)
can this be weld on with a mig welder?
cilvia
20
Apr 18, 2007 07:34 AM
drunknmunkypow
Aug 10, 2003 07:40 AM
B18CYAAA
Jul 14, 2003 03:22 PM
AVATAR
Jul 7, 2003 03:08 PM
