What Brake Upgrade for Front EK (Did Search)
Old Jul 28, 2004 | 07:12 AM
mrcch's Avatar
Default What Brake Upgrade for Front EK (Did Search)
I already have the rear discs, and a 15/16 MC with booster, and 40/40 valve, but I still need to replace the fronts due to wear and warpage. Any suggestions on what I can convert too other that upgrading to Aftermarket?
I did a search and could not come up with any good info. Thanks for any help.
Old Jul 28, 2004 | 07:46 AM
civic23g's Avatar
Default Re: What Brake Upgrade for Front EK (mrcch)
GSR fronts bolt on. All u need is the spindle from the GSR. I got the whole hub assembly with mine so if u get it that way it will go straight on, not sure if u can use the stock one.
Tom
Old Jul 28, 2004 | 08:40 AM
cre18's Avatar
Default Re: What Brake Upgrade for Front EK (civic23g)
or do the 99-00 si fronts, they will bolt on as well. i believe they are the same size as the gsr's too... anyone want to confirm this?
Old Jul 28, 2004 | 08:58 AM
justanotherbluesi's Avatar
I have a 99 civic Si with stock calipers, stock size brembo cross-drilled/slotted in front,stock size cross drilled in rear, with apex kevlar pads on all four corners, and stainless brake lines, thsi set worked very well for me at auto cross, i have zero brake fade now
Jdmsoles
Suspension & Brakes
May 17, 2009 09:04 PM
sirguy01
27
Oct 30, 2006 09:51 AM
Ashnice
Jun 30, 2004 02:59 PM
QCKGSR
Oct 14, 2003 03:22 PM
eg_nezay
Mar 7, 2002 07:26 AM
