What Brake Upgrade for Front EK (Did Search)
I already have the rear discs, and a 15/16 MC with booster, and 40/40 valve, but I still need to replace the fronts due to wear and warpage. Any suggestions on what I can convert too other that upgrading to Aftermarket?
I did a search and could not come up with any good info. Thanks for any help. https://honda-tech.com/forums/images...es/emsmile.gif |
Re: What Brake Upgrade for Front EK (mrcch)
GSR fronts bolt on. All u need is the spindle from the GSR. I got the whole hub assembly with mine so if u get it that way it will go straight on, not sure if u can use the stock one.
Tom |
Re: What Brake Upgrade for Front EK (civic23g)
or do the 99-00 si fronts, they will bolt on as well. i believe they are the same size as the gsr's too... anyone want to confirm this?
I have a 99 civic Si with stock calipers, stock size brembo cross-drilled/slotted in front,stock size cross drilled in rear, with apex kevlar pads on all four corners, and stainless brake lines, thsi set worked very well for me at auto cross, i have zero brake fade now
