Weird Overheating Problem
Old Nov 27, 2001 | 03:57 AM
sackdz's Avatar
Default Weird Overheating Problem
My '89 Si's temperature gauge has been on the rise, and I have to leave the heat on to keep it down. I have a new thermostat, but been too lazy to put it in. The weird part is that the temp gauge will go all the way up, yet the fan will blow cold air even when it's set to full hot. How is this possible? Is my gauge just faulty?
Old Nov 27, 2001 | 04:51 AM
Mugen Dom's Avatar
Default Re: Weird Overheating Problem (sackdz)
water pump try that
Old Nov 27, 2001 | 09:30 AM
sackdz's Avatar
Default Re: Weird Overheating Problem (jdmB18hatch)
Can a water pump be intermittent?
Old Nov 27, 2001 | 09:33 AM
Mugen Dom's Avatar
does the radiator get hot? could be ur temp senser to
Old Nov 27, 2001 | 09:44 AM
sackdz's Avatar
It's weird, one second the air will be cold, with the gauge on red, then after a second the air will be hot as a JV Cheerleader on prom night. Also, once it starts blowing hot, it will blow cold intermittently this makes no sense. the thermostat only stops flow through the radiator, right? Coolant is always flowing through the heater core correct? I'm thinking water pump now....
Old Nov 27, 2001 | 09:48 AM
Mugen Dom's Avatar
yeh open ur radiator to see if the coolant is flowing thru it when the thermostat opens thats how i learned to see if the water pump works
Old Nov 27, 2001 | 09:56 AM
Veil_Side_'s Avatar
You said your thermostat needs replacement. Do it. It might be that.
If the problem persist it probably is a faulty gauge. It has happened before to people I know.
Old Nov 27, 2001 | 10:40 AM
SiR Kid's Avatar
New User
Default Re: Weird Overheating Problem (Veil_Side_)
Make sure there's WATER in the system. Top it off... SOunds like the classic "crack in the plastic POS radiator" syndrome to me.
Old Nov 27, 2001 | 11:15 AM
sackdz's Avatar
Default Re: Weird Overheating Problem (SiR Kid)
No.
Old Nov 27, 2001 | 03:30 PM
RedRacerCivic's Avatar
to check if water pump el workin, squeeze the upper coolant hose to see if there is pressure.
HiChanDC2R
Aug 15, 2010 05:15 PM
miszjackie
Honda Civic (2001 - 2005)
12
Mar 25, 2010 05:46 AM
integraNooB
Mar 26, 2008 09:31 AM
94c1v1cex
11
Aug 7, 2007 06:56 PM
CA6VTEC
Aug 26, 2004 06:37 PM
