Dash pot for the throttle body
Old Jul 27, 2004 | 01:38 PM
4DRmafia's Avatar
Default Dash pot for the throttle body
do i need it on my d16a6 or can i remove that part and what does it do ?
Old Jul 27, 2004 | 02:29 PM
4DRmafia's Avatar
any 1 ?
Old Jul 27, 2004 | 02:44 PM
FalkenSiR's Avatar
Default Re: (SkipMic2006)
it prevents the engine from stalling when u get off the gas and put it in neutral. no , i wount think its a good idea to take it out.
Old Jul 27, 2004 | 03:01 PM
tysf's Avatar
Default Re: Dash pot for the throttle body (SkipMic2006)
you dont need it, i never hooked it up on my car. sometimes the idle searches around a bit but it's generally fine.
Old Jul 27, 2004 | 03:07 PM
ek_99_SiR's Avatar
Default Re: Dash pot for the throttle body (ninetone)
it wont hurt ot help u to remove it so id leave it
Old Jul 27, 2004 | 03:15 PM
Tyson's Avatar
it helps for start up and slowing down the throttle when you release the pedal quickly. when the engine is off, it will pull the throttle open just a bit to allow more air, to help start the car. when i had mine disconnected it would take a few more cranks to get started. otherwise, i didnt notice a difference.
Old Jul 27, 2004 | 03:33 PM
4DRmafia's Avatar
oka if i remove it can i adjust the idle screw back just a little more so it can have little air to go through when i start the car
Old Jul 27, 2004 | 03:52 PM
Tyson's Avatar
um, then youre idle will be off...
Old Jul 27, 2004 | 04:41 PM
4DRmafia's Avatar
well i mean after i adjust it to spec
DeLSoLRo
20
Apr 23, 2011 10:06 AM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
k_lude
Oct 2, 2006 07:25 PM
Jdmbsixteen
Feb 20, 2004 08:59 PM
