Car wont start (clicking) ???
Old Jul 27, 2004 | 11:44 AM
bo0sted's Avatar
Default Car wont start (clicking) ???
Ok so today I go out to drive my car and I turn the ignition and I just get a click noise. If I keep turning the ignition it just continues to click. My radio and headlights and everything else powered by the battery seem to work fine. I have never experienced this clicking before. It just came out of no where today when I went and tried to start the car. I reset the battery checked all battery connections and they are all good. Spark plugs are fine, no oil or anything on them. All fuses are good. Starter is wired correctly. The fuel pump chimes perfectly along with the main relay. I'm thinking the starter just went out, but a lot of the other threads I read with starters going out seem to start showing signs a few months before they are actually completely toast. Like I said this is the first sign of the clicking and the car wont turn over for anything.
Bottom line is it doesn't seem to be the battery since everything else is being powered perfectly. Would a starter go out just like that with no signs of problems? My car is a 2000 so I would think the starter would last longer then that. Let me know what you think.
Mike.
Old Jul 27, 2004 | 11:49 AM
saleensolution's Avatar
Default Re: Car wont start (clicking) ??? (MwGSR)
i know it sound stupid but double check ALL of your grounds like on the valve cover and the one thats on your tranny to the frame make sure that they are not corroded and make a good connection
Old Jul 27, 2004 | 11:57 AM
djpaul81's Avatar
Default Re: Car wont start (saleensolution)
im having the same problem, sometime when i try to start my car it just keeps clicking! but if i keep doing it eventually it starts! im thinking its the starter thats going bad. anyone else have suggestions
Old Jul 27, 2004 | 11:58 AM
Default Re: Car wont start (djpaul81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djpaul81 &raquo;</TD></TR><TR><TD CLASS="quote">im having the same problem, sometime when i try to start my car it just keeps clicking! but if i keep doing it eventually it starts! im thinking its the starter thats going back. anyone else have suggestions</TD></TR></TABLE>
good chance your starter is dragging and needs rebuilt
Old Jul 27, 2004 | 12:02 PM
bo0sted's Avatar
Yah thats for sure signs of the starter dieing.
Old Jul 27, 2004 | 12:03 PM
ProJectCvic's Avatar
It sounds like a starter to me. Hey..if you car is new, maybe it's still under waranttee.
Old Jul 27, 2004 | 12:04 PM
bo0sted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution &raquo;</TD></TR><TR><TD CLASS="quote">i know it sound stupid but double check ALL of your grounds like on the valve cover and the one thats on your tranny to the frame make sure that they are not corroded and make a good connection</TD></TR></TABLE>
Just went to check these wires and my trans ground and valve cover ground were not all the way tightened. I tightened them up and it started right away. That was a easy fix. That is like the only thing I didn't check. haha thanks. I feel stupid.
Old Jul 27, 2004 | 12:10 PM
Default Re: Car wont start (MwGSR)
glad to help you out
Old Mar 20, 2005 | 07:56 PM
Ge.ES.AHH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MwGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Just went to check these wires and my trans ground and valve cover ground were not all the way tightened. I tightened them up and it started right away. That was a easy fix. That is like the only thing I didn't check. haha thanks. I feel stupid. </TD></TR></TABLE>
where are these wires at? I may have the ssame problem. Anyone have any pictures or can explain to me where these grounds are?
Chris Teodoro
Mar 12, 2016 12:47 PM
inaety
Jun 24, 2011 12:57 AM
robble36
Oct 16, 2007 07:20 PM
Hatchman98
Apr 23, 2007 03:20 PM
junya16
Mar 1, 2003 07:30 PM
