axle options?
What are my options for axles?
As of right now i have a 91 STD hatch, that has the stock hubs and everything(smaller than the si/dx) I just snapped a brand new oem axle, again.. Im boosted. What options do i have for stock like axles? Can i swap just the dx/si hub into my STD knuckle? Is that even worth doing? Does anyone make aftermarket axles for the STD hubs?
thanks
pat
thanks
pat
Well are you breaking them because of wheel hop? If so, get a Jimfab and some poly bushings. From what I have read and herd, this helps wheel hop ALOT. And dont buy an OEM one everytime you break one. Look around here on Hondatech for STD axles, get a drivers side and passenger side so that you have them on hand. They are cheaper then buying from Honda and easy to find.
Blaze
Blaze
nope, wasnt from wheel hop. I was just pulling out of my driveway, and i got on it hard, pulled to 7500, shifted, and sheared the axle straight off.
Are the lifetime axles from advanced auto any good, im thinking about buying one, i need the car..and they will replace them when i break em.
I need to find si hubs..
Modified by phatrick2332 at 1:32 PM 7/27/2004
90Rexx
12
Jul 26, 2009 02:57 PM
