daily drivers... what turbo mani are you using??
when i was driving my boosted prelude i had some heat issues under the hood, at ful boost with the wastegate wide open, the car had a tendancy to over heat. i was running one of those POS obx style manifolds at the time that i am sure had a major contribution to the cause.
with any luck, my next project will involve a B series, so i wanna get an idea of what manifolds people are runing, and what kind of power they are making, and if its daily driven, please
TIA
TIA
This is on a customers CRX with a b16 swap. I have them for $300. 304 stainless, tubular, garrantied for life. no problems with them. http://rs02.securehostserver.c...10006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost2cure »</TD></TR><TR><TD CLASS="quote">
This is on a customers CRX with a b16 swap. I have them for $300. 304 stainless, tubular, garrantied for life. no problems with them. http://rs02.securehostserver.c...10006 </TD></TR></TABLE>
thats the same thing i had on my Prelude that caused the alternator to repeatadly skull **** itself due to heat
what do you mean by a chrome over a log? Are you reffering to a equal length over a log? Equal length CAN give you more torque. On a 1.8t VW motor we showed a 15 tq gain over the ATP log style. I have not dynoed the honda set ups i have yet so i won't make any false claims. It's also better flow than a log style.
thanks for hijacking my thread, you wanna prove a point, make a different thread, your manifold is NOT what i am looking for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">so i wanna get an idea of what manifolds people are runing</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">thanks for hijacking my thread, you wanna prove a point, make a different thread, your manifold is NOT what i am looking for</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">
?</TD></TR></TABLE>i already stated that his manifold was not what i was looking for then he proceeded to post about how his manifold was so great
10,000 miles on my daily driven bubba built ls/vtec using a Rev hard manifold.... Works Great!... no boost creap or anything.... .... on 14 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- »</TD></TR><TR><TD CLASS="quote">inline pro...so far so good. Runs no hotter than it did N/A</TD></TR></TABLE>
same here
same here
why are you guys making a corelation between engine temp and the manifold?
"when i was driving my boosted prelude i had some heat issues under the hood, at ful boost with the wastegate wide open, the car had a tendancy to over heat."
^that sounds like the car wasn't tuned properly to me or had a cooling system problem. Under the hood would include the inside of the engine right? I'm assuming the water or oil temp gauge was used to determine it was hot...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">why are you guys making a corelation between engine temp and the manifold?
^that sounds like the car wasn't tuned properly to me or had a cooling system problem. Under the hood would include the inside of the engine right? I'm assuming the water or oil temp gauge was used to determine it was hot...</TD></TR></TABLE>
wastegate placement WAS an issue, where the wastegate was located, all the heat hit the alternator, destroyed 2 of them, and at times, caused the car to overheat
never had problems with the GReddy kit though
