cat raddling
Old Jul 26, 2004 | 10:10 PM
kupras's Avatar
Default cat raddling
Just started noticing that between 3-4k RPM on my gsr my cat is making this raddling noise. I have about 90K on it with all tune ups. Its been doing that more lately and im just wondering if its time for me to replace the stock cat or if its just some kind of shield thats hitting it. Anybody have any input
Old Jul 26, 2004 | 10:50 PM
iH8RICERZ's Avatar
Default Re: cat raddling (kupras)
I know at one time, i had a terrible rattle from my cat area at 4k rpm............i went back and re-tightened the bolts on the cat and my problems went away...also, check your heat shields or remove them. If the problem continues, then replace the cat
Old Jul 26, 2004 | 11:51 PM
GZR4DR's Avatar
Default Re: cat raddling (iH8RICERZ)
Do you have a stock header? If so 90% chance thats the culprit. Of all my friends with Integras (5), each and every single one has had the downpipe start to rattle. At first I thought it was the cat just like yourself, but after swapping the header and keeping everything else it went away. On a couple of my friends cars we replaced the downpipe and it fixed the problem as well. The noise only occured between 3-4k rpm's. Hope this advice helps you.
Old Jul 27, 2004 | 12:14 AM
LSTEG96's Avatar
Default Re: cat raddling (GZR4DR)
i thought my cat was rattling too... then i thought the heat shield fell off...turns out a header bolt had snapped and was rattling, and i tore the mount out of my tranny (what i thought was the heat shield falling off).
good luck to u, hopefully it wont turn out the same!
sitinduk
Jan 31, 2008 06:17 PM
JDMEK9R
Jan 9, 2008 10:58 AM
Token Blk Guy
Sep 14, 2002 10:46 AM
onyx00
Jul 21, 2002 06:38 PM
JoshRambo
Oct 1, 2001 02:31 PM
