Is there a way to make the power steering not so powerful?
Old Nov 26, 2001 | 08:37 PM
matthewk's Avatar
Default Is there a way to make the power steering not so powerful?
I don't want to remove the power steering but i would like to make it help a little less. Just about twice the resistance there is now would be great. Is there a way to do this?
Thanks!
Old Nov 26, 2001 | 08:47 PM
OneThirtyEight's Avatar
Default Re: Is there a way to make the power steering not so powerful? (matthewk)
I wish,
you could try adjusting your steering rack a litte?
Old Nov 26, 2001 | 08:48 PM
matthewk's Avatar
Default Re: Is there a way to make the power steering not so powerful? (97blackteg)
Is there an adjustment that you know of?
I am wondering if the ITR steering is less assisted? It would see that this would not be a really high demand part from wrecked ITR? Maybe it would be cheap?
Thanks!
Old Nov 26, 2001 | 09:36 PM
jdmotorsports's Avatar
try the aem power pulleys. they replace your power stearing and alternator pulleys. they worked for me. made a little power and didnt affect much at all. thats the only way to mess with the p.s. that i know of.
Old Nov 26, 2001 | 09:37 PM
Mr. Softee's Avatar
Default Re: Is there a way to make the power steering not so powerful? (jdmotorsports)
power steering is for girls
Old Nov 27, 2001 | 03:21 AM
madslackin's Avatar
Drain some fluid? Just messin with ya...
You could always switch to a manual steering rack from a Civic. Just removing the belt from the p/s pump will tighten up the feel a lot, but it does require a lot more effort to turn the wheel in parking lot situations.
Justin
Old Nov 27, 2001 | 06:53 AM
mercury's Avatar
New User
Default Re: Is there a way to make the power steering not so powerful? (madslackin)
I think you'd be very disappointed to find that it requires a lot more turns of the wheel to go from lock to lock on a manual steering car. Parallel parking and 3-point U-turns become a real pain. Slow U-turns on the backroads will also require a lot of steering wheel shuffling.
Toks
Jan 21, 2009 02:10 AM
i HAVEtheADVANtage
Mar 17, 2003 10:32 PM
SpoonboyChoi
Mar 6, 2003 09:48 AM
Turbo Powa
24
Feb 15, 2003 06:37 PM
CmptchAV6
Aug 23, 2001 05:01 PM
