Need Help Deciding what ECU for an LS turbo. HELP
I've done many searches, but have got no information that applies to me. Ok heres the problem.
I have a OBD2 97 LS turbo. my question is what would be the best route to take if i want to use hondata. Would i have to get a different ECU, if so which one is reccomended? OBD2 to OBD1 conversion??? someone please help me out.
Would this cause a problem with emissions?
Thanx in advance
Thanx in advance
I'm researching the same things...I think the popular setup is getting a p28 ecu, and you'll need a wireharness converter. Any will do, but if you don't trust some home made ones i think SKunk2 makes one.
best thing to do is convert your car to OBD1 with the few harness adapters out there.
as for ecu choice, any OBD1 ecu will work if you're going hondata because you will be reworking the fuel/timing maps anyhow.
i already have a p28 virgin sitting in my room. im just wondering what is the best recommended for our setups. and im also worried about emissions
JLitalia
Jan 17, 2010 01:53 PM
slowazzhatch
Mar 7, 2003 03:51 PM
