car making noise
i purchase my CRX almost a month now..it came with coil over but haven't lowered it yet untill yesturday..the left side of the coil over is making noise and is very shaking..i was jw if any of you CRX owner's had this problem before..On cracks and Bumps the car sounds like it has dead shocks which it ain't cause i jus replaced them..i be glad if anyone help..thnx..IS IT THE COIL OVER...this only happens when i lowered the car..
make sure your strut is tight the two bolts in the engine bay... and it may be your axle on the side binding up i had the same problem except mine was more like a vibrating..
with coil-overs your coil will lose contact with the strut bottom with large holes because of the strut moving and the coil staying stationary so if you have more than a 2 inch drop you will always have this problem. so raise it or live with it. I DO
ed4_civic
Mar 28, 2010 11:46 AM
greenwar
Apr 26, 2008 06:11 PM
blurrrcivic94
Feb 8, 2004 07:09 PM
ArchAngel Sabastian
Feb 5, 2002 11:51 AM
