Map sensor problem
Old Nov 26, 2001 | 05:33 PM
SjCiViCHB's Avatar
Default Map sensor problem
Hey sup. I got this map sensor problem. Ecu throwing code 3, thats map sensor correct? well i replaced the map sensor with two new ones, still same code. I replaced the ecu, and still the same code. Can anyone tell me why its doing this?
93 D16Z6, I/H/E, Jg Camshaft, AEM adj. Cam gear advanced 4degrees. ive been having this problem ever since i blew the head of my engine when my car over heated.
When i start the car, the car hesitates to like start, i have to hit the gas a few times, and then the car idles fine. does anyone have a idea of whats wrong with my engine or a clue or something? Thanks. Peace.
Old Nov 26, 2001 | 08:44 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Map sensor problem (SjCiViCHB)
first of all, with cam ADAVNCED 4 degrees it will throw things off.
WHY advanced?
Old Nov 26, 2001 | 08:49 PM
John's Avatar
New User
check your ECU ground... a faulty ECU ground will set off the MAP sensor code... (at least on mine it did)... do you have a V-AFC?
Old Nov 27, 2001 | 12:26 AM
SBR*EG4's Avatar
Default Re: Map sensor problem (DunReit)
make sure throttle body vaccum port is clean,vaccum line is good,harness ground located on top of coolant water neck is tight. if alls well put back to stock settings and start diagnosing with helms book!
Old Nov 27, 2001 | 02:26 PM
SjCiViCHB's Avatar
Default Re: Map sensor problem (N4Y2C0E)
WHY advanced?
i advanced it because when it was retarted 4 degrees the car ran so crappy, and luggish. The car runs way stronger when i advanced it. i dont know why it would throw something off though, i use to have the car advanced 9 degrees.
Where is the ECU ground at? and nope i dont have a V-AFC, im looking for one though.
where are all those hoses at? i dont know which ones are which. and i dont have a helms manual, i havent recieved it yet. can you show me a pic or something? imma bout to try to attempt to install my bored throttle body too so any help with that since im checking those lines?
Thanks everyone.
Dc_Ek
Feb 13, 2013 11:47 PM
92ehatch
16
Feb 19, 2007 11:41 PM
89hb
Jan 6, 2003 06:11 AM
Xsi
Sep 23, 2002 07:50 AM
