Valve Adjustment?
I went out to my car the other day and started my car. My corner light was out so I went to fix it. I heard a ticking from my engine. It's gotten louder within the last few days and only occurs while the car is warming up. Once warmed up the ticking goes away. Is this a sign of a valve adjustment being needed or something else?
stupid cams wearing out... and ya if it is getting worse you might have started to get to a soft spot in the metal of the cam or cams amd they are starting wear faster, just do the adjustiment and be down with it, when i didn mine it got soooo quiet,mine were really off
No, it's nothing serious. Adjust the valves, it'll go away. The only way you'll need to replace any of the valvetrain is:
1. You fucked your motor by over-revving or bending any of the valves.
2. You used some sort of nitrous and warped or cracked some of the valves.
3. Your camshaft broke to pieces.
4. You want to upgrade your valvetrain to rev to 8,500 RPM after getting it tuned.
Racewerkz
Jan 26, 2011 07:55 AM
Fighterinsnatch
16
Jul 26, 2007 08:02 AM
