timing question...need help asap
Old Nov 26, 2001 | 04:52 PM
SjCiViCHB's Avatar
Default timing question...need help asap
is it safe to advance your ignition timing and advance your cam timing?
Old Nov 26, 2001 | 05:55 PM
stkd16z6's Avatar
Default Re: timing question...need help asap (SjCiViCHB)
yes, it can be done....but it is prefered to dyno tune. is this for a SOHC Vtec or DOHC motor?
Old Nov 26, 2001 | 07:39 PM
SjCiViCHB's Avatar
Default Re: timing question...need help asap (stkd16z6)
sohc vtec, i was wondering cause i tried to set the ignitiong timing back to stock, the red mark, and i when i do it, the engine gets hella loud. the red mark is stock timing right? man i need to ge the car dialed in on the dyno, but after i get the stupid check engine light off.
Old Nov 26, 2001 | 07:44 PM
stkd16z6's Avatar
your cam gear could be off, be sure to check both marks on the gear and the crank to make sure they are both TDC.
Old Nov 26, 2001 | 07:52 PM
SjCiViCHB's Avatar
hmm....how can the cam gear be messed up? how can i check to see that its right? i had it installed by a professional. sorry i dont really know much abou this stuff
Old Nov 27, 2001 | 01:11 AM
evo's Avatar
evo
New User
If i've advance the cam gear do i have to advance ign timing, as i know the IN cams is connect to distributor>
Old Nov 27, 2001 | 02:42 AM
Mista Bone's Avatar
D Tranny Guru
just cuz they were a pro don't mean crap. I've had to help fix quite a few swaps that the local "pros" did.
Like wiring up a ZC into a CRX Si. About 8 wires at the ECU were hacked. WTF?
Old Nov 27, 2001 | 02:43 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: timing question...need help asap (evo)
with SOHC's (all I work on) if you advance the cam you must RETARD the ignition timing. As you advance the cam, you also advance the ignition timing.
Old Nov 27, 2001 | 01:56 PM
siisgood00's Avatar
New User
For every 1 deg you advance the cam timing, you must retard the ignition timing 2 deg.
Old Nov 27, 2001 | 02:21 PM
SjCiViCHB's Avatar
Default Re: timing question...need help asap (siisgood00)
okay, so im suppose to retard the ignition timing correct? thanks guys. ill get to it right now.
ek4__
Aug 3, 2006 08:15 PM
JdmIntegra98
Jun 10, 2004 01:48 PM
HXvtec
Mar 23, 2004 09:12 AM
hondacivic4g
Jul 16, 2002 12:33 PM
DaNish
13
Jan 24, 2002 12:00 PM
