do 98 gsr engines have 2 vtec engagements?
Old Jul 25, 2004 | 02:54 PM
redhatchb18's Avatar
Default do 98 gsr engines have 2 vtec engagements?
just what the title says. my car feels like vtec kicks in at 4800 and then again at 5600. my old b16 never did that? the gsr engine is in a 91 si and converted to obd0 so would that have anything to do with it?
Old Jul 25, 2004 | 02:58 PM
Quick99Si's Avatar
Default Re: do 98 gsr engines have 2 vtec engagements? (babyboib16)
No, it's not a "double VTEC" or whatever some people call it. There's the VTEC crossover like B16/B18CR and the opening of the shorter intake runners. IAB = intake air bypass found on B18C1 and H22A1/4 whose slight power increase can be mistaken for VTEC.
Longer runners are generally better for low end power
Shorter runners are generally better for top end power
I actually think Honda officially calls it a "2-stage VTEC"
Adi
Old Jul 25, 2004 | 03:10 PM
Default Re: do 98 gsr engines have 2 vtec engagements? (Quick99Si)
so wich one is the vtec engagement?
Old Jul 25, 2004 | 03:30 PM
DefiantGSR's Avatar
4400
Old Jul 25, 2004 | 05:37 PM
gsrlkn412s's Avatar
5600 is where the vtec kicks in. you can tell by the intake noise that you are on the hotter lobes. at about 4400 is where the dual stage intake manifold butterflies open up to acheive high end horsepower
Old Jul 25, 2004 | 05:43 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: do 98 gsr engines have 2 vtec engagements? (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">4400</TD></TR></TABLE>
......shorter runner come in later to optimize high end power, 5600 revs.
Old Jul 25, 2004 | 05:51 PM
Default Re: do 98 gsr engines have 2 vtec engagements? (gsrlkn412s)
damn 5600 is late as hell. i know my boys came in at 4800 but he had a 94 gsr.
Old Jul 25, 2004 | 07:05 PM
Quick99Si's Avatar
H22 is 4800 and 4900rpm. I'm 99% sure that 4800 is the IAB and 4900 is VTEC crossover. The GS-R seems a lot "father apart"
Adi
Old Jul 25, 2004 | 07:11 PM
so what is a good place to set the vtec at on a gsr?
Old Jul 25, 2004 | 07:19 PM
DEVIOUS_EG*'s Avatar
stock
Old Jul 25, 2004 | 07:24 PM
Quick99Si's Avatar
Default Re: do 98 gsr engines have 2 vtec engagements? (DEVIOUS_EF*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* &raquo;</TD></TR><TR><TD CLASS="quote">stock </TD></TR></TABLE>
Not necessarily. Honda seems to have the VTEC crossover take place a short time after the optimal point in B/H series motors. H22's for example are stock at around 4900rpm, optimal at 4400-4600rpm. B16A's are at 5400rpm, optimal at around 5200rpm. I guess it gives you the feeling of a bigger boost when it engages late.. because you're bogging so much on the idle cam lol
Adi
honda_lemus541
May 26, 2008 05:43 PM
type-GGSR
Apr 3, 2008 11:31 AM
SimplyTron
13
Oct 13, 2007 02:16 PM
Hapa88
Apr 22, 2004 09:20 AM
GSR-T-
May 21, 2003 07:07 AM
