safe redline for a b20 vtec
Old Jul 25, 2004 | 02:44 PM
BustedEG's Avatar
Default safe redline for a b20 vtec
what would be a safe redline for a b20b stock bottom end, with a stock b16 head on it jdm airbox with k&n, and a dc header + exhaust.
Old Jul 25, 2004 | 02:50 PM
SprayinCX's Avatar
Default Re: safe redline for a b20 vtec (BustedEG)
7800 rpm.
anything after that i will not last. as far as a daily driver goes.
Old Jul 25, 2004 | 02:55 PM
chad's Avatar
Moderator
if you don't have rod bolts....then 8200
took mine to 8500 daily for 38,000 miles....
on STOCK ROD BOLTS.....
Old Jul 25, 2004 | 02:56 PM
kaoss_11's Avatar
B A N N E D
Goto 8200
Old Jul 25, 2004 | 03:21 PM
BustedEG's Avatar
Default Re: (kaoss_11)
i typically take care of my motor, i dont really get on it much on the street, only to get moving because i have a b16 which doesn't make very much power until higher rpms. so if i had that motor setup, and drove the same way and occasionally went to the track, 8000-8200 would be a safe redline when i did get on it? i would assume that the b20 would have enough torque to get me going most of the time without taking it above 6000 for average acceleration.
Old Jul 25, 2004 | 04:44 PM
chad's Avatar
Moderator
Default Re: (BustedEG)
you can shift at 3000 rpms with the b20 and be shifting into more tq than your b16 will ever make!!!
Old Jul 25, 2004 | 06:34 PM
b20bvtec'd's Avatar
There is no need to go past 7500 rpm's with your current setup. It doesn't make power past that.
Old Jul 25, 2004 | 07:06 PM
chad's Avatar
Moderator
Default Re: (b20bvtec'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20bvtec’d &raquo;</TD></TR><TR><TD CLASS="quote">There is no need to go past 7500 rpm's with your current setup. It doesn't make power past that.</TD></TR></TABLE>
ummm....mine made power to 8500 and was still climbing on stock cams....
Old Jul 27, 2004 | 04:34 PM
b20bvtec'd's Avatar
Default Re: (chad)
his setup won't got the dyno sheets to prove it. His setup is exactly the same as mine.
Old Jul 27, 2004 | 04:38 PM
b20bvtec'd's Avatar
Default Re: (chad)
He also states above in the first post it's a b20b not your b20z. You have your dyno sheets?
Old Jul 27, 2004 | 04:46 PM
notstock93's Avatar
I revved my LS motor (stock rod bolts) to 7,500RPM for about 5 months and then it spun a bearing. If you have ARP bolts, 8k would be safe. However, be warned...the B20 block wasnt made to see those high RPM. Somethiing besides rod bolts may give out.
Should make great power, though.
Old Jul 28, 2004 | 07:00 AM
B20JonLee's Avatar
Shift where your power falls off on dyno. I am using all stock internal's and have taken my B20 to 8k for a couple years now with no issues. I would recommend an accurate tune though. As far as building power, I am on stock GSR cams and I develop peak HP at 7800 rpm and it pulls strong to stock rev limit.
Tito559
Feb 23, 2011 01:18 PM
rEnZ94tEgGy
Oct 5, 2008 06:18 AM
cxhb
May 26, 2005 09:14 PM
JdmHybrid.
52
Jun 16, 2003 11:24 AM
trix are for kids
May 29, 2002 08:27 PM
