valve clearance question
Old Jul 25, 2004 | 01:02 PM
temp's Avatar
Default valve clearance question
if i run CTR pistons in a B16a block will i have any valve clearance issues with S2S1 cams?
Old Jul 25, 2004 | 01:14 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: valve clearance question (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">if i run CTR pistons in a B16a block will i have any valve clearance issues with S2S1 cams?</TD></TR></TABLE>
not with factory head tolerances and a stock head gasket.
I have JE 11.5:1's with Toda spec C's and over sized valves. Head is milled .10 and a Honda head gasket. Still no clearance issues.
Old Jul 25, 2004 | 01:50 PM
turboZChatch's Avatar
You will be fine the same setup used to be in the kids car I work with ctr pistons with skunk stage 3 cams and no clearence issues at.... all go for it
Tech6023
Sep 12, 2005 09:26 PM
crxste
Nov 11, 2004 11:03 AM
SupaFly_Honda
Oct 15, 2003 08:23 PM
crxste
Sep 7, 2003 08:29 AM
McFly
Mar 2, 2003 08:01 PM
