Does size really matter???
I'm putting a set of 17x7 rims on my 99 civic ex w/ ground control coilovers.
My question is what size tires would be best for me. Would 215/45/17 be too big??
Also some brand recomendations(sp??) would be apreciated.
17" will fit fine as long as the offset is correct. Call tire rack and see what offset they recomend. But like DragIIcivic said, I also would not recomend 17s.
I've heard that 17's can make your car noticabely slower. Only if your car has reasonable amount of horsepower. 400 hp Rx7's don't need to worry about it.
I would think about the roads you drive on....if they are shitty(last time I was in Athens there was alot of construction going on) you might want more sidewall.
AND THIS IS MY 1000th POST!!!!! WOOOHOOOO!!!!!!!!!!!!!!
and yes this is being used under permission, and is the same list as http://home.earthlink.net/~cvlocas
[Modified by fifthgearonline, 10:42 AM 11/28/2001]
i would go with 16s, just to be safe.
but its your car i cannot decide for you.
im going to get 16s for my ride though, my 17s bent to dirty hell on my goneda
