tire size..
Old May 19, 2003 | 07:57 PM
Accord98's Avatar
Default tire size..
205/40/17, be too small for a 6th gen accord?...or should i go with 215/45/17?
or 215/50/17?...
Old May 19, 2003 | 09:28 PM
jeffhdub2(accord)is's Avatar
Default Re: tire size.. (AccordKid98)
I have 205/40/17 and my car is low the work ****
Old May 19, 2003 | 09:51 PM
paul9luap's Avatar
Default Re: tire size.. (sparky55)
What is the width of your wheel? 205/45/17 is a pretty standard size for 17x7 rims. 205/40/17 would be way too small for an accord, but technically, it will still fit the rim, it would just look like a strung out rubber band, and if you don't have a camber kit, say bye bye to those expensive tires.
Also, you want a decent amount of tire sidewall so that way when, and believe me, it is WHEN, not IF, you hit a pothole, you won't damage your rim.
Old May 20, 2003 | 04:38 PM
Accord98's Avatar
Default Re: tire size.. (paul9luap)
17 by 7 i believe, and i'm planning on lowering it as soon as i get money for some springs/coilovers. I'm gonna have to see what kind of drop i need.
170 is ur goal huh?
lol well i'm 5'11 168 pounds :D
dont forget NOT to skip ur meal times...eat healthy and pump em blocks.
Old May 21, 2003 | 09:29 PM
kaleide's Avatar
You could easily go to a 235/40/17 and if your worried about lowering and rubbing, a 225/45/17 will work with zero rubbing!!
Old May 22, 2003 | 06:31 AM
AccVic's Avatar
Default Re: (kaleide)
205/40/17 is just too small that's the max size for a Civic go with at least 225/45/17 that's a good fit for your car
Old May 22, 2003 | 08:42 AM
dantastic's Avatar
most 17x7 rims are +40 offset. anything bigger then 215 width will rub. i ran 215/45-17 kumho 712's. worked great.
Old May 22, 2003 | 09:00 AM
btlfed1's Avatar
Default Re: (dantastic)
I am running 18 x 7.5 with 225 40's and they fit perfect.
Old May 22, 2003 | 09:19 AM
professorman's Avatar
i have 215/45-17. works great
Old May 22, 2003 | 09:42 AM
iam7head's Avatar
Default Re: (profroopchan)
low profile tires looks better but it dont think it's worth all the bouncy ride(if you area suck like mine that is).
Old May 22, 2003 | 10:48 AM
dantastic's Avatar
Default Re: (btlfed1)
oops i forget.. most ppl can run 225. i cant cuz i have corrected camber. 215's rub sometimes too. (5g ex)
Old May 22, 2003 | 10:59 AM
btlfed1's Avatar
low profile tires don't give you a bouncy ride if you have a good suspension set up with adj dampers. You might feel a little bit stiffer but if you set it up right there will not be a big difference.
pphan3
Mar 23, 2016 10:32 PM
stnwag0n
Feb 24, 2003 10:19 AM
lodown414
Nov 4, 2002 10:11 PM
Doogie Howser
Jun 24, 2002 05:34 AM
SpeedMonkeyRacing
Jun 21, 2002 02:31 PM
