HELP, Car slipping out of gear.
Old Jul 25, 2004 | 12:41 PM
cvc323's Avatar
Default HELP, Car slipping out of gear.
I was driving on the highway today in 5th gear and after a while it slipped out of 5th and back into neutral. It did this a few times after about a minute or two in gear. What does this mean? Do I need a new clutch? I just had a new one put in when I put in the new motor last year. Any ideas?
Old Jul 25, 2004 | 12:58 PM
sloweh3's Avatar
Default Re: HELP, Car slipping out of gear. (cvc323)
Sounds to me like your syncros in fifth gear in the tranny are going out.
Old Jul 25, 2004 | 01:45 PM
vtecn8ive's Avatar
Default Re: HELP, Car slipping out of gear. (H82BLGL)
What if it shifts in all gears fine but when I shift it in Reverse it kinda takes some effort like i gotta force it in. Sorry not trying to jack the thread.
Old Jul 29, 2004 | 08:39 AM
sloweh3's Avatar
Default Re: HELP, Car slipping out of gear. (vtecn8ive)
That kinda sounds like my tranny right there. I usually throw it in gear first, then throw it in reverse, because I've had a friend who's car wouldn't go in reverse, so he jammed it in as hard as he could... well, now he has no reverse at all. It's like the gear isn't there.
Old Jul 29, 2004 | 08:45 AM
KaoticSnow's Avatar
lol
"quick get out and push me out of the parking spot"
Old Jul 29, 2004 | 09:47 AM
mikerbike's Avatar
Default Re: HELP, Car slipping out of gear. (KaoticSnow)
There is a ring on the synchro that goes in with it when you push the fork into gear. The ring acts like a C-clip when it is pushed in, holding the synchro and drive gear in place. If it is a big problem, you will want to take apart your transmission and see where that ring is. If it came off the synchro, it is probably ground up into a thousand pieces and stuck to the magnet in your transmission. I've been looking for a synchro set for a while now and haven't found anything. If it is too much for you to bear, buy a new transmission.
Old Jul 29, 2004 | 12:57 PM
sloweh3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaoticSnow &raquo;</TD></TR><TR><TD CLASS="quote">lol
"quick get out and push me out of the parking spot"</TD></TR></TABLE>
LOL, actually, that's what he had to do most of the time.
Old Jul 29, 2004 | 03:07 PM
hondaxsimike's Avatar
what time is it when yer tranny slips outta gear???? time to get a new tranny.
if one gear is doing it then odds are the other gears might go too over time. check your local tranny shop for overhaul prices, or you can usually get a used tranny in good condition at your local junk yard.
stevevang
Apr 14, 2014 02:47 PM
Eks_86
Dec 12, 2010 08:54 AM
choptopprelude
Nov 7, 2007 02:20 PM
vietnogi
Feb 2, 2006 11:36 AM
HPCO$T
19
Feb 1, 2005 11:37 AM
