D-series Turbo manifold........................
Old Jul 25, 2004 | 10:32 AM
CRXBart's Avatar
Default D-series Turbo manifold........................
I am thinking about boosting my beater EF hatch that I swapped a d16z6 in. I am looking at turbo manifolds and I don't want to spend a whole lot on my beater car. I found this http://cgi.ebay.com/ebaymotors...=WDVW has anyone used one? It looks pretty nice, lots of bracing shouldn't crack. Thanks in advance guys.
Old Jul 25, 2004 | 11:05 AM
turboda6's Avatar
Default Re: D-series Turbo manifold........................ (CRXBart)
just make one, i made mine for 50 bux... just go on ebay and look for a exhaust side flange, then get the turbo flange for whatever turbo ur gonna use, then jus get some short t and bend pipes. it may not be the prettiest but its cheaper
Old Jul 25, 2004 | 11:17 AM
beepy's Avatar
It really looks like SSAC is making attempts to reinforce their manifolds. This one does look much sturdier.
Old Jul 25, 2004 | 12:45 PM
CRXBart's Avatar
Default Re: D-series Turbo manifold........................ (beepy)
So did you have one of their older ones? Would you reccomend this one?
Old Jul 25, 2004 | 01:19 PM
project dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">It really looks like SSAC is making attempts to reinforce their manifolds. This one does look much sturdier.</TD></TR></TABLE>
attempt is correct, recently redzone performance put on on a customers car and it cracked aroudn the runners and at the headflange, even one of the braces broke off.
Old Jul 25, 2004 | 04:25 PM
Forest1's Avatar
It would work...
Old Jul 25, 2004 | 04:31 PM
CRXBart's Avatar
Default Re: (Forest1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forest1 &raquo;</TD></TR><TR><TD CLASS="quote">It would work...</TD></TR></TABLE>
No kidding I was not aware of that. Do you have anything to contribute or are you just wasting bandwidth?
Old Jul 25, 2004 | 04:39 PM
igo4bmx's Avatar
check out http://www.bmcrace.com for really affordable log manifolds...
i'm getting mine in a couple of weeks
Old Jul 25, 2004 | 04:45 PM
CRXBart's Avatar
Default Re: (igo4bmx)
Yeah somebody suggested those, I'm thinking that might be the ticket. I want a mitsu flange on mine though going ultra cheap low budget boost. Beater car once again. I'll have to see if they can flange for a mitsu turbo.
Old Jul 25, 2004 | 05:24 PM
beepy's Avatar
Default Re: (CRXBart)
If not I know where to get mild steel or stainless DSM TD05 flanges.
Old Jul 25, 2004 | 07:52 PM
liam821's Avatar
25 Year Member
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">If not I know where to get mild steel or stainless DSM TD05 flanges.</TD></TR></TABLE>
http://www.roadraceengineering...s.htm
Old Sep 7, 2004 | 06:40 PM
MooreBoost's Avatar
Default Re: (liam821)
Bump. Lets see what the ninjas run.
Old Sep 7, 2004 | 07:54 PM
sethm's Avatar
You could always use a cx manifold, those go really cheap.
Old Sep 8, 2004 | 02:13 PM
G3NR8's Avatar
Default Re: D-series Turbo manifold........................ (sethm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sethm &raquo;</TD></TR><TR><TD CLASS="quote">You could always use a cx manifold, those go really cheap.</TD></TR></TABLE>
^^Probably the cheapest way to go. Just get an adaptor plate for whatever turbo you are using. Check turbod16.com. Theres a guy who sells adaptor plates on there for like 20 bux. You could have a complete mani and adaptor for under $100 easy.
Old Sep 8, 2004 | 03:58 PM
USDM 4G VTEC's Avatar
Default Re: D-series Turbo manifold........................ (G3NR8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G3NR8 &raquo;</TD></TR><TR><TD CLASS="quote">
^^Probably the cheapest way to go. Just get an adaptor plate for whatever turbo you are using. Check turbod16.com. Theres a guy who sells adaptor plates on there for like 20 bux. You could have a complete mani and adaptor for under $100 easy.</TD></TR></TABLE>
yup
get my adapter and a HF manifold for like 40 and u done
Old Sep 8, 2004 | 04:17 PM
illestrolla247's Avatar
Default Re: D-series Turbo manifold........................ (USDM 4G VTEC)
thats what ive got HF and adapt plate
Sketch_hs
Apr 10, 2007 02:38 AM
berts95ej
Welding / Fabrication
Mar 9, 2006 10:18 AM
Radyjr
Jul 17, 2005 11:31 AM
dblock91
13
Feb 3, 2005 06:03 PM
Dent Free
Jun 21, 2004 04:24 PM
