B20/VTEC - Turbo Lag
Old Jul 25, 2004 | 06:28 AM
Islandspeed's Avatar
Default B20/VTEC - Turbo Lag
I've got a B20/VTEC Turbo (.48 x .63) and am experiencing a bit of lag when the turbo tries to spool up. I know I need to open up the exhaust (cuttently running 2.25") but any other ideas on minimizing the lag until I can come up with the money for a 3" Hayame exhaust?
Done so far;
Minimized the size of the vac lines
Ensured the BOV is workin properly to eliminate compressor surge
Check oil delivery to turbo
To Do;
Change O2 sensor
Thanks...........
Old Jul 25, 2004 | 06:32 AM
ABK's Avatar
ABK
Default Re: B20/VTEC - Turbo Lag (Islandspeed)
what a downpipe are you running?
Old Jul 25, 2004 | 06:35 AM
Default Re: B20/VTEC - Turbo Lag (ABK)
2.25" flared connection to Turbo and welded to flex pipeunder base pan...........
Old Jul 25, 2004 | 06:40 AM
ABK's Avatar
ABK
well you might wonna get that thing up to at least 2.5" or bigger if possible. o2 housing and downpipes can be really responsible for turbo lag. As for exhaust just take your exhaust off, your car won't be terribly loud since you got a turbo. It will sound actually pretty nice, and reduce your lag.
Old Jul 25, 2004 | 07:43 AM
EM1 MIKE's Avatar
If you run open downpipe watch out for 5-0 and jackers. The sound of a turbo spoolin can turn a lot of heads.
Old Jul 25, 2004 | 07:49 AM
ABK's Avatar
ABK
Default Re: B20/VTEC - Turbo Lag (EM1 MIKE)
yeah it's not really loud though, it just sounds like a madd semi turbo. Exhaust sound is pretty much canceled out. I see tons of people running open downpipes around here mostly SRT-4s non of them get touched, unless they **** around.
Old Jul 25, 2004 | 08:17 AM
Luserkid's Avatar
You sure you have no boost leaks?
1YellowSol
Mar 17, 2014 07:14 PM
nightshift
Oct 15, 2009 02:13 PM
looseOFFboost
Jul 23, 2009 07:54 PM
