Can you turbo a b20?
Re: Can you turbo a b20?
ANother thing you might want to consider is putting arp head studs AND MAIN STUDS!! It really helps hold the bottom end together. Even for the turbo. I have a sc61 turbo for my b20/v havnt installed it yet, someone before me had it on his ls/v and said it pulled like a son of a b****
What's the build of the engine? It all depends on your build & goals. Is it a straight B20 or a B20/Vtec?
As stated before in this thread, you can turbo anything. Be sure your motor is healthy though if you're leaving it 'stock'. Start w/ a leakdown test or compression check before you even do anything & check how the numbers look.
