will H22 injectors work on obd1 gsr motor
as long as the injectors are obd1, they will fit. if they are obd2 injectors you would have to solder on obd2 injector clips. the h22 injectors are with it due to they are 290cc injectors. good size injector for a all motor build. i use to run them on my lsvtec
