O2 sensor wiring help
On the clip from the car, there is a white, a green, and a black wire w/ a white strip, and a black wire w/ a yellow stripe. On the sensor there is a white, a green, and 2 solid black wires. . Does it matter which one is hooked up to which? If so how do I tell?
Thanks!
Modified by drumnbassej1 at 8:16 PM 7/24/2004
Thanks!
The car side white/red wire is connected to the sensor side white wire.
The car side green/black wire is conencted to the sensor side green wire.
The car side black/yellow wire is connected to one of the black wires on the sensor side.
And the car side black/white wire is connected to the other black wire on the sensor side.
The two black ones are interchangeable since it's a resistor/heater. As long as it has a pos. and neg. from the car side, it'll work fine.
