ECT sensor fails and/or MCL isnt up?
Old Jul 24, 2004 | 03:28 AM
prelude-bb3's Avatar
Default ECT sensor fails and/or MCL isnt up?
engine coolant temperature sensor (ECT) isnt giving me any messurement even on warm or cold engine
and when i unplug the connector MCL checklight doesnt come up with code 6
what does this mean
i thougt on 20 degrees it have to be min 2000ohms????
my car runs fine but....i only wanted to check this with a digital multimeter,but i faild in getting any messurement
Old Jul 25, 2004 | 01:33 AM
nobody?
Old Jul 25, 2004 | 02:05 PM
jmcclell's Avatar
Default Re: (prelude-bb3)
The ECT sensor should read approx 3K Ohms at 20oC.
Are you sure you are checking the correct sensor?
Remember that the prelude has 2 separate sensors for reading coolant temperature.
The dash guage uses the single pin sensor located on the front left hand side of the cylinder head. Next to this, is the two pin sensor used by the ECU to detect coolant temperature.
You could be disconnecting the VTEC Pressure Switch (located on the VTEC solenoid) or the Radiator Fan Switch (located on the thermostat housing) which will NOT immediately show a "MIL" light and error code.
Hope this helps.
Old Jul 25, 2004 | 11:42 PM
thx ,ive an sohc non vtec on aprox 200Hp *GG*
no... ive check the 2 pin one...hmm,dunno why theres no messurement.
dohcvtecpower
Sep 30, 2010 05:11 AM
ONEFASTJDM
Jul 16, 2009 10:37 PM
accorracer
Sep 19, 2004 05:35 PM
chattownrexer
Jul 10, 2004 02:45 PM
Nerv2g
Jul 29, 2003 08:19 AM
