Garret T3/T04E turbo user question
Old Nov 26, 2001 | 11:15 AM
boosted hybrid's Avatar
Default Garret T3/T04E turbo user question
Do I need to buy a flange with a threaded neck for the oil inlet, like the oil drain? The inlet looks to be threaded -4AN on the turbo, but it has two bolts on either side of the inlet which indicates to me that a flange is needed. If I do need the flange where can I purchase one?
Thanks, Jeff
Old Nov 26, 2001 | 11:21 AM
dbman96's Avatar
New User
Default Re: Garret T3/T04E turbo user question (boosted hybrid)
I believe if you use the threaded inlet you do not need a flange but I may be wrong. Mine only has a flange on the outlet to allow for a barb fitting. The inlet is just a 90 degree AN fitting screwed into the housing.
Old Nov 26, 2001 | 11:27 AM
Rob03Pro5's Avatar
Default Re: Garret T3/T04E turbo user question (dbman96)
You shouldn't have to have a flange for the oil feed. Just use some teflon paste for the fitting and you're set.
miguel329
Aug 3, 2010 09:51 AM
QwkD16
Oct 3, 2007 03:43 PM
boost fed ls
Aug 11, 2003 05:05 PM
BoosterChair
Jul 16, 2003 10:03 PM
Pat
Apr 13, 2003 10:26 PM
