Garret T3/T04E turbo user question
Do I need to buy a flange with a threaded neck for the oil inlet, like the oil drain? The inlet looks to be threaded -4AN on the turbo, but it has two bolts on either side of the inlet which indicates to me that a flange is needed. If I do need the flange where can I purchase one?
Thanks, Jeff
Thanks, Jeff
New User
Re: Garret T3/T04E turbo user question (boosted hybrid)
I believe if you use the threaded inlet you do not need a flange but I may be wrong. Mine only has a flange on the outlet to allow for a barb fitting. The inlet is just a 90 degree AN fitting screwed into the housing.
Re: Garret T3/T04E turbo user question (dbman96)
You shouldn't have to have a flange for the oil feed. Just use some teflon paste for the fitting and you're set.
