Quick question about boost and rod bearings...
I think i might have a bearing beginning to **** out, according to my oil i jus drained out. no biggie. but on a stock block that never has been touched, are ALL the rod bearings the same color from the factory or no?
THanks
Wade
I know to keep them a little loose for boost i heard...
THanks
Wade
ya know, i thought so, i was just told by a few ppl that from the factory they were all the same color, they jus had diff sizes in case u spun a bearing and had to do machining and such and needed a slightly diff size then..
thanks
wade!
thanks
wade!
no, whoever told you that was confusing Honda colored bearings with normal oversized bearings that every other manufacturer uses.
