Bearing Sizes help!
Old Jan 27, 2006 | 11:48 AM
9295EJ-t's Avatar
Default Bearing Sizes help!
it seems that d16z6 honda bearings have been discontinued.. and i need to know the thicknesses of the bearings..
i have a choice between .25mm, .5mm, .75mm and 1mm in thickness for rod bearings.. my color codes were: rod bearings= green yellow brown brown.. main bearings= 2pink 2yellow 1 green (babbb and 22123) about how thick is the thickest honda bearing (color code: black)? i was told by a honda technician that he would just use all blacks for main and rod bearings cause they are the thickest in size..? is that the smart thing to do for a rebuild?
well.. anyways. my real question is how thick are the blacks? 1mm? i need to know asap!!
and if i went the ACL route, what should i go with? the standard size or .25mm?
http://www.autohausaz.com/sear...20Set
and how good is the shipping? fast?
and what about main bearings? standard or .25mm?
Old Jan 27, 2006 | 07:21 PM
d16dcoe45's Avatar
Default Re: Bearing Sizes help! (9295EJ-t)
Measure your old bearings with plastigauge and take it from there. You want anywhere from 0.0015-0.0020" on the mains, and maybe 0.0015" on the rods.
Old Jan 28, 2006 | 07:09 AM
9295EJ-t's Avatar
Default Re: Bearing Sizes help! (d16dcoe45)
thanks!
TurboKneeGrow
Mar 18, 2008 07:22 PM
TurboKneeGrow
Mar 18, 2008 02:58 PM
flyingduck04
Nov 29, 2006 10:02 AM
bunnyrabbit
Mar 29, 2004 05:20 AM
