92-95 civic exhaust question
Old Jul 23, 2004 | 09:44 AM
lillthingz's Avatar
Default 92-95 civic exhaust question
Does anyone know if 2dr exhaust will fit on a 3 dr car? also does anyone know if you can pass inspection with a high flo cat?
Old Jul 23, 2004 | 10:16 AM
AmauryR's Avatar
Default Re: 92-95 civic exhaust question (lillthingz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lillthingz &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if 2dr exhaust will fit on a 3 dr car?</TD></TR></TABLE>
Well, to my knowledge I believe the 2dr and 4dr exhausts are interchangable, if I remember correctly, the 3dr has the rear section bent slightly different (because the 2dr/4dr the bumper goes out more, so the muffler sits back more or has a longer tip), and the hangers are off (I know on the rear section), as far as the b-pipe I think its very close, I haven't tried the b-pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lillthingz &raquo;</TD></TR><TR><TD CLASS="quote">also does anyone know if you can pass inspection with a high flo cat?</TD></TR></TABLE>
If its a visual inspection and its a oem-looking high-flow cat (not one of those ebay blingy test-pipes they pass off for cats), then ur good. If you did get the ebay test-pipe cat then I'd throw the stock cat back on. Also they might say something if the exhaust sounds funny because of the highflow cat.
hth, if I'm wrong then somebody correct me, thnx.
-l8r
Old Jul 23, 2004 | 10:39 AM
lillthingz's Avatar
I see I thought that the 2 and 3 dr would fit up almost exactly. But i gues not. As for the cat i supposibly need to get a new one because i failed emissions bad i had too much Nox so i duno what to do? help someone...
Modified by lillthingz at 12:29 AM 7/24/2004
Old Jul 23, 2004 | 03:31 PM
lillthingz's Avatar
Default Re: (lillthingz)
Come one someone else has to know something about this stuff...
Old Jul 23, 2004 | 05:05 PM
alleyezonme's Avatar
im not 99% sure you won't pass with a high flow cat.
m2s4drespecial
Honda Civic (2001 - 2005)
Apr 10, 2007 01:19 AM
gsp ej1-em1
11
Jul 16, 2006 07:59 AM
gimmethat
Oct 4, 2005 10:59 PM
playboynemesis
Mar 15, 2005 04:02 PM
JforJonathan
May 12, 2003 02:01 PM
