parts for auto to manual swap 92-96 prelude
Here is what i have:
clutch pedal bracket
throttle cable
rubber tranny mount
2 slave cylinders ( used)
shift boot
Starter bolts
front tranny bracket
spring for clutch pedal
motor mounts
energy suspension rear mount insert
brake pedal
both clutch switches
clutch master cylinder reservoir (used)
flywheel cover
gas pedal
clutch pedal
shift lever
flywheel bolts
linkage
All is new unless i specified it wasnt. The rest is brand new straight from honda. That is all the major stuff i have. I have a ton of little pins bolts nuts etc also all new from honda. Let me know where you are located and we will work something out if interested. It is about $500 worth of parts asking $200 shipped obo
throttle cable
rubber tranny mount
shift boot
Starter bolts
motor mounts
brake pedal
flywheel cover
gas pedal
clutch pedal
shift lever
flywheel bolts
linkage
okay, thanks. I'll wait for the email to show up. Did you send it to Jackson@keddies.net? I can't remember which email h-tech has...
The only way I would back out is if I end up finding a low-mileage front clip from canada where it's JDM but still LHD. If I end up just getting the motor/tranny though I will DEFINATELY need clutch parts for the swap so that's a definate.
I'm ordering my motor/clip hopefully on friday, so if it's just the motor I can be ready to buy next week at the latest. Hope that helps...if you want I'll email you either way to let you know if I found a clip or not.
Later!
Later!
sageuvagony
Mar 28, 2007 09:14 PM
