rear disk e-brake sucks help!!!
Old Jul 23, 2004 | 04:29 AM
sircrxracer's Avatar
Default rear disk e-brake sucks help!!!
I have replaced everything Honda cables new pads and rotors and still my e-brake won't hold my car WTF
I checked all the calipers they seem to work good I can feel in grab slightly but it won't hold the car. I have ajd the cables so I have no clue is there a secrect to this dam thing? On my 88 it works mint I thought rear disk on my 90 would be alittle better WTF. Rob
Old Jul 23, 2004 | 05:45 AM
crx_88_si's Avatar
adjust the ebrake cables.
Old Jul 23, 2004 | 06:14 AM
b18CrxSi91's Avatar
71.179.86.205
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote">
I checked all the calipers they seem to work good I can feel in grab slightly but it won't hold the car. I have ajd the cables so I have no clue is there a secrect to this dam thing? On my 88 it works mint I thought rear disk on my 90 would be alittle better WTF. Rob</TD></TR></TABLE>
READ!
I too have the same problem on my 91 si. no ebrake for me.
I have adjusted the cable the pads are fine...I don't know what the problem is.
Old Jul 23, 2004 | 07:21 AM
Ok I don't know why but on my 88 I adj the cables tighter and it works very good........ that's what I have been doing on my 90 so I tried the other way and it works WTF I made it loser and the e-brake is way up in the air and it holds the car good??? I have no idea why this works but hey now I can do a burn out for my slicks YES!!!!
So try that all you 90-91 CRX's see if it works for you. Rob
Old Jul 23, 2004 | 08:33 AM
EL Vap133's Avatar
Default Re: (sircrxracer)
I have 91 crx si rear disc brakes on my 88 crx and I don't have that problem. Where are you adjusting the cable from?
Old Jul 23, 2004 | 09:14 PM
b18CrxSi91's Avatar
71.179.86.205
Default Re: (EL Vap133)
So try that all you 90-91 CRX's see if it works for you. Rob</TD></TR></TABLE>
God damn Japs.....
Ill have to try it, ill let you know if it works.
Old Jul 23, 2004 | 09:18 PM
EL Vap133's Avatar
Default Re: (b18CrxSi91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18CrxSi91 &raquo;</TD></TR><TR><TD CLASS="quote">
God damn Japs.....
Ill have to try it, ill let you know if it works. </TD></TR></TABLE>
*Cough* God damn what?
Old Jul 23, 2004 | 09:47 PM
sm00thk0zz's Avatar
Probably one or both of ur calapers are bad. I had same problem, but had another set of trailing arms w/ breaks. Swapped out one and now they hold like a CHAMP! Try jacking ur rear up, putting on the e-brake and seeing if you can spin the tires with ur hand.
Old Jul 23, 2004 | 10:37 PM
eda6's Avatar
Default Re: rear disk e-brake sucks help!!! (sircrxracer)
The e-brake cable should be fully tensioned between 6-10 clicks.
Is yours setup like this?
Old Jul 23, 2004 | 11:40 PM
Full Race A6's Avatar
Default Re: rear disk e-brake sucks help!!! (eda6 hb)
I dont know what I would do without my ebrake.
First week I bought the car I parked on a slight hill, put it in first and left. Came back in the morning and it was resting on the truck I was parked infont of.
I havent left teh car without it yet.
Couldnt tell you an answer to your problem though
What track you go to? Kayuga? Shannonville?
Old Jul 24, 2004 | 01:21 AM
b18CrxSi91's Avatar
71.179.86.205
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
*Cough* God damn what? </TD></TR></TABLE>
J A P S
mynameisChris
Aug 15, 2009 06:57 AM
schueytenten
10
Aug 29, 2008 01:35 PM
blue_hatch
Suspension & Brakes
Dec 17, 2007 05:48 PM
LSVTEC 91 Civic
Honda Fit
37
Nov 15, 2007 05:52 AM
pennies_hatchie
13
May 30, 2005 07:46 PM
