HELP...rear brakes wont decompress..
well, i just got done replacing the rear rotors and brake pads on my del sol vtec and now the car wont budge. for example, if you have it in nuetral and the ebrake down, you cant push the car back or forward. if you drive it, it smokes. its like the ebrake is on but its not. i pushed the ebrake cable in the rear and there is slack there. any help would be great.
Re: HELP...rear brakes wont decompress.. (pennies_hatchie)
If there rear disk you have to turn the puck down clockwise not compress it like you would on the front set.
Re: HELP...rear brakes wont decompress.. (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">If there rear disk you have to turn the puck down clockwise not compress it like you would on the front set.</TD></TR></TABLE>
im not understanding. this is what i did...
1. take off rims
2. take off old rotors
3. take off calipers
4. remove pads
5. put new rotors on
6. hammer the pistons on the calipers in
7. put the pads on
8. tighten everything back
now the rear wheel wont budge..its like its lock. the ebrake is also down. help if you know what i did wrong. thanks
1. take off rims
4. remove pads
7. put the pads on
The pistons you hammered in also have to be screwed in. That is why it has those notches in them. Your pistons are not decompressed the way they should be.
Should have done a smidgin of research before doing this. Oh well.
Here's a link on what you should do from the sig of nocturnaldragon
https://honda-tech.com/zerothread?id=898904
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">
1. take off rims
4. remove pads
7. put the pads on
8. tighten everything back</TD></TR></TABLE>
Wow. A.) never hammer brake calipers or pistons, ever. B.) rear disc brakes use a screw-type piston to actuate the pads.
You probably destroyed both calipers. Remanufactured ones from Autozone are about $70 each with core . That sucks, broham.
1. take off rims
4. remove pads
7. put the pads on
Re: (notfastenough)
wrong link here you go
https://honda-tech.com/zerothread?id=935087
and yea i dont think you should hammer anything you can also use a c clamp.
Re: HELP...rear brakes wont decompress.. (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
You probably destroyed both calipers. Remanufactured ones from Autozone are about $70 each with core . That sucks, broham.</TD></TR></TABLE>
damit
damit
Re: (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">wrong link here you go
and yea i dont think you should hammer anything you can also use a c clamp.</TD></TR></TABLE>
and i tried the c-clamp on the rear (didnt know i had to turn it) and of course it didnt go in, so i used the hammer..stupid me
Unceasing Measure
Re: (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">and i tried the c-clamp on the rear (didnt know i had to turn it) and of course it didnt go in, so i used the hammer..stupid me</TD></TR></TABLE>
Not stupid: just inexperienced. Hey, you made the piston go in, right?
Unfortunately, the rear calipers are pretty sensitive and you can destroy them very easilly. Yours are almost definately toast
try sticking a piece of metal in them once you remove them and step on the brake. So you dont pop the piston out and see if they still work. Im pretty sure there junk now, you can allways take them apart and see if its all good. Ive never taken a brake apart before so im not sure whats all involved with that.
