Cleaned the IAC ... now car stalls at idle?
Old Jul 22, 2004 | 07:23 PM
JPsprintCIVIC's Avatar
Default Cleaned the IAC ... now car stalls at idle?
well my idle has been rough so I've been reading up and ne of the first things suggested was to check the IAC valve. I did that and the port on the intake was caked w/ black ****. I cleaned all that out, reinstalled everything and took it for a ride around the block and it stalls on me any time I let off the throttle.
got it to idle fine while in the driveway just now, but once i touch the trottle, or even turn the a/c on/off, it boggs down
Any suggestions on how i can solve this one?
By the way it a d16y8 w/ greddy kit and im using the hack
Old Jul 22, 2004 | 07:58 PM
PH3593A's Avatar
Default Re: Cleaned the IAC ... now car stalls at idle? (JPsprintCIVIC)
Reset your ECU. Maybe?
Old Jul 22, 2004 | 08:34 PM
JDMlyfestyle's Avatar
did u ever tamper with ur idle screw?
Old Jul 23, 2004 | 05:02 AM
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">did u ever tamper with ur idle screw?</TD></TR></TABLE>
thats exactly what i needed to do ... to bad i figured that out 3 hours later
There's an adjustment screw on the top of the TB to the right of the MAP sensor. I pulled off the little plug/cap thing and turn the screw counter-clockwise and kept turning the a/c on and off and tapped the throttle to see if the rpm's dipped anymore. After a few adjustments, I idled normal and now when I rev, it always returns to a perfect idle.
thanks JDMlyfestyle
Old Jul 23, 2004 | 05:17 AM
no problem bro
LukieLuc
Sep 19, 2007 07:37 PM
eg6nes
Feb 21, 2005 03:57 PM
ILOVEGIRLS
Mar 31, 2004 12:58 PM
quik2kSi
Dec 27, 2003 09:04 AM
killa_lude
Aug 16, 2003 08:33 AM
