which way is better for the feed line?
Old Jul 22, 2004 | 05:32 PM
GReddy SI's Avatar
Default which way is better for the feed line?
or
as u see on the second one it hits the manifold a bit
would i be ok like that? or just put it like on the first pic?
Old Jul 22, 2004 | 05:43 PM
Nihilation's Avatar
My guess would be like the first pic, but make the line a bit shorter so it fits better.
Old Jul 22, 2004 | 06:03 PM
GReddy SI's Avatar
Default Re: (Nihilation)
bump anymore comments?
Old Jul 22, 2004 | 06:10 PM
Tchleung's Avatar
100% go with the first one, but shorten the line by about a foot
Old Jul 22, 2004 | 06:12 PM
B18Flip's Avatar
Default Re: (Tchleung)
of the 2 i'd go w/ the first...but i think it would be better if you ran a 90 deg fitting from flamenco-t so it's not touching you manifold
Old Jul 22, 2004 | 06:19 PM
fastcivicboy's Avatar
def. the first. But yeah like stated before shorten the line.
Old Jul 22, 2004 | 06:20 PM
drvfast's Avatar
Default Re: which way is better for the feed line? (GReddy SI)
To me, the second pic is a better way to route the oil feed.
Old Jul 22, 2004 | 06:24 PM
pngfolife's Avatar
Default Re: (B18Flip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">of the 2 i'd go w/ the first...but i think it would be better if you ran a 90 deg fitting from flamenco-t so it's not touching you manifold</TD></TR></TABLE>
That's probably the best way and cheap too.
Old Jul 22, 2004 | 06:26 PM
AlphaKennyWun's Avatar
Default Re: which way is better for the feed line? (drvfast)
neither
get a 45 degree AN adapter, turn it to the side facing dizzy and run it like pic 2
Old Jul 22, 2004 | 06:32 PM
warwagon's Avatar
Default Re: which way is better for the feed line? (Turbo Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Chris &raquo;</TD></TR><TR><TD CLASS="quote">neither
get a 45 degree AN adapter, turn it to the side facing dizzy and run it like pic 2</TD></TR></TABLE>
that or a 90 to the front
Old Jul 22, 2004 | 06:50 PM
Bailhatch's Avatar
Default Re: which way is better for the feed line? (warwagon)
neither are acceptable. way too close to the manifold. A 90* facing foreward as far to the passenger side as possible, without the line touching the comp cover, is the only way short of running hardline down the back of the center section.
Old Jul 22, 2004 | 07:44 PM
Jim Truett's Avatar
Default Re: which way is better for the feed line? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">neither are acceptable. way too close to the manifold. A 90* facing foreward as far to the passenger side as possible, without the line touching the comp cover, is the only way short of running hardline down the back of the center section.</TD></TR></TABLE>
Agreed. Both methods leave it way too close to the manifold, with one even touching it. That would cook the oil feed to the turbo, especially with the elevated EGTs during boost. I recommend a 90 degree fitting and running the line out from underneath the manifold.
Old Jul 22, 2004 | 11:56 PM
GReddy SI's Avatar
Default Re: which way is better for the feed line? (Jim Truett)
problem is that i cant get a 90degree bend in there cuz the turbo piece wont move at all so i cant screw it on
Old Jul 23, 2004 | 12:09 AM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI &raquo;</TD></TR><TR><TD CLASS="quote">problem is that i cant get a 90degree bend in there cuz the turbo piece wont move at all so i cant screw it on </TD></TR></TABLE>
Seperate the CHRA(center housing rotating assembly) from the turbine housing (6 13mm bolts) and then put in the 90deg. fitting in there.
Old Jul 23, 2004 | 03:18 AM
Boostage's Avatar
Default Re: which way is better for the feed line? (Arturbo)
Either way and you will eventually set the car on fire..
Old Jul 23, 2004 | 07:27 AM
Tushner's Avatar
Default Re: which way is better for the feed line? (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">Either way and you will eventually set the car on fire.. </TD></TR></TABLE>
Old Jul 23, 2004 | 08:07 AM
GReddy SI's Avatar
i did that and that middle piece wont move at all
how can i get it to move?
Old Jul 23, 2004 | 08:05 PM
Arturbo's Avatar
Better than steak
25 Year Member
If you took the bolts out of the turbine housing it will come right out.
Old Jul 23, 2004 | 09:14 PM
eh294's Avatar
i used a 45 degree fitting and didnt have to move anything. just shaped up 2 corners on the fitting and it cleared fine... good luck finding a 45degree #3jic fitting!!!!
Old Jul 23, 2004 | 09:45 PM
Snail Tuning's Avatar
Default Re: which way is better for the feed line? (eh294)
i had the same problem with my HKS manifold and Garret T-25 turbo.
i traded stan a strait oil line for a 90 degree and it solved the problem.
i then bought some shielding from summit racing and coverd the feed line for added protection.
check my sig for updated pictures.
justYncredible
Jul 16, 2012 10:22 AM
577HondaPrelude
Sep 25, 2007 09:49 AM
Unjockable
Apr 30, 2005 05:30 PM
hondaguyef
Oct 11, 2004 09:58 PM
turbo craig
Sep 25, 2002 11:45 AM
