code 41: Primary Oxygen sensor Heater. What does this mean?
There are codes for o2 sensors and primary o2 sensors. So what is a primary o2 sensor heater?
Modified by allmotorEG-SI at 10:22 PM 7/22/2004
Code 41-Primary oxygen sensor heater is the rear o2 sensor(after the cat). I just threw the same code yesterday morn.
Honda wants like $230 for it...Im gettin one for $50 from my buddy. Good luck man
..adam..
..adam..
Have you just reset it to see if it was a fluke? Maybe the O2 sensor is just starting to go bad.
I see them in the classifieds all the time for about $30. I sold mine for $30. Bought a brand new OEM one for $50. Just look around.
There are 4 wires to the O2 sensor.
2 are the signal and its ground.
The other 2 are for the heater element inside the O2 - think whats inside a light bulb for lack of a better description.
One wire is fed +12 while the ECU uses a PWM gnd signal on the other wire.
To properly troubleshoot, simply unplug the O2 sensor and using a multi-meter measure the heater resistance: should be 15-40ohms (Helms spec).
I once had a code 65, which is just the heater code for the 2nd O2 sensor - ended up having to replace it - it can't be fixed.
Don't go to the dealer either - OEM O2's can be had for around $150 from places like hondaautomotiveparts.com.
i got the same code 41...on my 98 civic hatch....62K miles....think that's covered under warranty? anyrate, but did the exact routine - cleared the codes...checked the wires..unplugged battery...but my car still idles low and still dies each time i come to a stop...kinda hard to the revs high hhehehe
sounds pretty early to have o2 sensor (heater) problems..
hondaautomotiveparts.com huh?? i'll definitely hit that up. glad i did a search.
thanks!!!
thanks!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow98sedan »</TD></TR><TR><TD CLASS="quote">Code 41-Primary oxygen sensor heater is the rear o2 sensor(after the cat). I just threw the same code yesterday morn.
..adam..</TD></TR></TABLE>
The primary o2 is the first O2 *BEFORE* the cat. Costs $160 for the oem part if you buy it online from http://www.hondaautomotiveparts.com or http://www.slhondaparts.com . I believe that http://www.prostreetonline.com is selling a replacement for a reasonable price.
http://www.hondaautomotivepart...82%29
Bossup!
Sep 9, 2009 07:35 PM
JoshJosephKeith
May 4, 2009 04:38 PM
