need help asap!!!!!!!!!!!!
sounds kinda like a timing issue, check your timing if its right then fix the knock sensor, if not then fix the timing and the knock sensor. That sensor should effect timing so it may the the cause of your problems.
AnAccordIsForever
Nov 13, 2007 08:31 AM
