How to remove slight bumps and scratches from plastic bumper?
Old Jul 22, 2004 | 06:24 AM
Xymox007's Avatar
Default How to remove slight bumps and scratches from plastic bumper?
In my rush to get to work this morning, I was backing up, and very lightly bumped the brick wall on my rear, plastic bumper. It's not a major cosemetic problem by any means, but none the less I'm angry with myself for making the error.
Is there a step procedure for removing the "brush burn" scratches from my incident? I'm thinking of going home and washing/waxing/polishing the area, but didn't know if there was something else I could use/try. Any suggestions would great
Old Jul 22, 2004 | 12:25 PM
Bill Hook's Avatar
Default Re: How to remove slight bumps and scratches from plastic bumper? (Xymox007)
Sanding.
You could then get it repainted.
Old Jul 22, 2004 | 02:19 PM
IVI's Avatar
IVI
Default Re: How to remove slight bumps and scratches from plastic bumper? (Bill Hook)
see if you can buff it out. use very very little rubbing compound, if you use too much itll dull the paint because it has tiny sand like particles in it.
as for the bumps, you cant. as far as i know.
Old Jul 22, 2004 | 03:01 PM
Xymox007's Avatar
Default Re: How to remove slight bumps and scratches from plastic bumper? (IVI)
thanks guys. i'm going to try some 3M Finish Restorer. Hopefully that will do the trick. I *heart* 3M products.
H.I CTR
Paint and Body
Dec 11, 2008 10:51 PM
dingobat
Paint and Body
May 17, 2007 09:15 AM
mamaboy
Jun 16, 2005 09:03 AM
turbotime
May 2, 2005 06:40 PM
Xymox007
Jul 22, 2004 06:03 AM
